Having Ignition Switch Troubles
viperjmk
Key switch will not release to off position when car is shut off and in park. Depressing the shift button on the automatic shifter sometimes causes and solenoid noise in the steering column. The key switch then releases to off position and I can remove the key. I'm guessing that the switch at the base of the shifter has something to do with this. Can you buy just the switch or do you have to replace the whole shift mechanism.
