having a problem help please
tps volts?
Having a problem now with my tps changed it out 2 times and still getting the code p0122 car won't shif until I hit 35 it might be a short in the wire got one of the things to test it 1 out of 3 lit up figure one is ground? Not sure but should it light up on all of them? Changed the plug with a good one I had and still same problem
Re: tps volts?
Not likely. However Scottydoggs will tell you all about how the wiring over the exhaust will go bad and you may have an issue in the wiring and not the sensor.
Yeah I'm going to try and get a new wiring harness today for a 98 to match the motor and computer I have ( I have the 97 body and harness right now) and if I change that would that maybe help?
I have a 98 one that's tuned for my car when I put the motor in I forgot to change it so I'm using the 97 for now but I wanna get my computer in its from dh I think they don't make them anymore
