Harmonic balancer question
gbgn1
Ive got a l67 in my project car and right now it has a fbody flywheel installed. Would it be ok if i installed the fbody balancer? Would that equal it out? Im assuming you cant run a s/c balancer with the na flywheel.
Thanks!!
I don't think it matters at all.
Just run whatever balancer you need to run, if you are staying supercharged, keep the L67 HB. 2 belt setup is better IMO.
From what I've read there is a very small difference in the flex and balancers between the NA and SC motors. However I've swapped then both ways and run any and all mixes of them w/o issues. Currrently I am running an 2000 L67 flex with a 2007 NA balancer on an 07 NA motor.
