khornocker
hello, I've searched the forum a bit but still need some help.
when I bought my 2005 GTP a short while ago I noticed that its very hard to fill up the gas tank. the pump will shut off after a few seconds. the check engine light also came on with a P0446 Evap code. I already replaced the Vapor canister vent solenoid and that didn't fix my issue. im getting 12 volts with the key on at the vent solenoid wire harness, and when I apply 12 volts to the solenoid using a battery I can hear it open and close. however, once I plug the solenoid into the wire harness it does not open or close. could this be a pressure sensor?
I was hoping I could find a vent hose that might be clogged but I cant find one. please help.
