kking89
Okay so i got these Halo/Led headlights for Christmas. i believe they are Dash Z brand. Here is a link to the exact headlights, just not on my car http://articles.dashzracing.com/wp-...rix-projector-headlights-97-03-19-600x450.jpg. My problem is when i install both headlights, for one i have no place to ground the bare wires too, only the Blinker/Flasher lights but when i ground it to them, all the lights work fine..EXCEPT when i turn my blinkers on. Or i should say my super cool dual blinker flashers. because it literally makes all the lights on my car flash, even when the flashers are not on. Undid the Halo and Led part, and just had the plug n play lights hooked up same problem still happened, and it only happened after i put the passenger headlight in, when the driver one was in my itself everything worked fine. Checked all my fuses that would cause that problem and they were are all fine. I dont know what else i could do besides maybe make a separate switch for the LED and Halo, but i dont know where i could run the wire through to the inside CLEANLY.
i was thinking about running it through the driver side fender to inside but every time you would open the door you would see wires and that's to ghetto for me. Any suggestions or ideas welcome
