blueguy
The Blue One
The extra boost isn't what gives you knock; the extra heat is. This is why you can change nothing other than adding an intercooler, drop pulley sizes and see no knock. So yes, that's an accurate statement. All things equal, denser, cooler air is more desirable.
Otherwise we'd have to up pulley sizes in the winter when the air is cooler/ denser but we don't because the accompanying temperature change offsets the increase in air density (and more).
Actually, many people DO up pulley sizes in winter to combat knock. Hotter air means LESS dense air, which means LESS knock. Reason why I was able to get away with a 3.0" in the summer with no intercooler, meth, pump gas...dumb amounts of timing...and then we had to richen up the AFR and up to a 3.1" in the winter...yeahhhhh buddy.
That's proven.
Also proven that as soon as you are moving, the ambient air temps are the same on an open cone as they are on a superawesomecoldairfenderwell intake setup...and the ONLY time this would benefit...is at the track.
90% of the cars here don't even see the track...and the ones that do are basic 3.4"~ setups that will gain nothing from running an intake setup that is supposed to have "colder" air.
Also, you do know the GenIII M90 is probably one of the worst, heat soaking, parasitic roots blowers out there? I'd be willing to bet...if we are being accurate...and measuring the air temps that matter, say...post blower? The superawesomecoldair intake...will have the same post blower temps as the open cone...because...the pre-blower air temps aren't gonna get into dat injenz...its dat retarded hot post blower air. So, like you said...unless there is an intercooler, or say...a methanol injection setup...COOLING the intake charge, POST blower...it's all worthless...
So basically just read: $50 HomeDepotRacing Intake > $3934985743095204587204 K&N CAI, MSP CAI, JMB FWI, SLP CAI, ZZP Intake...etc...etc.
