GXP Rear Brakes Help
asite57
If I can get my hands on so used set of rear calipers and pads is it just bolt on and go to my 99 GTP? Or is there bracket work or a new banjo bolt needed or something like that?
Rear Upgrade:
Using the GXP rear caliper and brake setup will require a bit of work for the 04+ guys, but the 97-03 guys can just bolt the GXP rear rotor and rear caliper right in. For the 04+ guys, see here:
Grand Prixs Of North America • View topic - Complete GXP Brake setup on a 04+ with working E-brake
This is the only upgrade for the Rear that we have. I would recommend this upgrade only if you have an itch to burn some money and have every modification possible. This upgrade is nice because you do get a vented rotor in the rear.
That being said, I know of someone parting out a GXP near us.
