mkyota1
Hi guys. I have picked up a 1999 gtx around a month ago and have been reading and reading on this site and others to try to build it up a little. After much research I decided on a 3.4 setup. First, I started with a set of speed daddys with no cat and a cherry bomb to go with the existing slp catback. Second, I did the LIM and did a mild port job on the s/c, nothing crazy. At this point I got a Aeroforce guage. I was not thrilled with the ~5* of kr even after the headers. I have no idea what it was before? I tried some al 605s that didnt help.
At this point I thought that I would try a tuned pcm. I went with Will at Overkill. I went ahead and ordered it for the 3.4 with the mods that I already had with the hope that it would help with the kr. I was informed that it would be "OK" to run for a while on the stock pulley it would just be a little rich at higher rpms or under load. It almost got rid of all of it. I would sometimes get little blips under .5*. I noticed the LTFT was reading clost to 0 at idle and very light load, but it is around -10 to -12 on the highway. Seems to be pulling a little fuel. I thought it might be like he said about running the stock pulley.
So I went on and ordered the 3.4 pulley and some al104's. I installed them and reset the pcm and went for a drive. After about 45 min of normal driving to let the computer learn I started to get on it. Now I was getting up to ~6*kr. I know not good. The LTFT was still about the same. So not wanting to hurt the motor I put back on the stock pulley and the 605s. The o2 sensor was locking in good about .930.
I would like to know what you guys think about my problem. I am pretty confident that it is not false knock because it goes away with the new pcm and stock pulley. I have tried some seafoam to try to clean the injectors and remove some carbon from the combustion chamber but no help. I have read about possible hot spots due to headgasket overhang. Does this sound like a tune problem to you guys? How much do you think rockers would help? Enough to be worth it?
Sorry about the novel. Hehe. Any thoughts would be appreciated. Thanks in advance.
