Gtx has a turbo!! lol
Re: i got the 01 gtp for my nic build lots of pictures ( 98gtx and 97gtp to make one)
What did you strap the chain to to pull the engine out?
there are two brackets I hooked it took, its not out yet just need to move it around and wiggle it out, my next door neighbors asked if I could turn my lights off tonight at 10 so they could have a fire
and watch the meteor shower
Yeah its all coming out hopefully tomorrow and my 98 motor will be in there until I can build this one with my cam
Nice, well I'm subbed cause i'm gonna be doing the same thing. PS how did you disconnect the trans?
Engine and trans out the top still seems crazy to me have fun. Out the bottom is so much easier
its not crazy at all if I can handle it lol my buddy did this at his shop before too its easy just to unhook it all and pull it up,
progress yeahhhh
Re: motor pulled from 01 gtp for my nic build lots of pictures
Very let down i was anticipating alot of pictures not 3
so where exactly did you disconnect the transmission from the car?
The trans is held down by its trans mounts, which is 2 bolts. When its still bolted to the motor it will come out with it.
In a quick run down, the engine and trans must be unbolted at their mounts, remove the cooler lines, both CV axles, any wiring, power steering items, AC compressor and few other smaller parts and it will come out the top.
here for you Matt a few more
Sorry fell asleep last night not used to getting up at 4:30am for work, but thank you fivefingerdeathpunch for answering that for me, comopaint0707 now that I know how to pull it the other motor is coming along fast I just need to pull the CV axels and undo my power steering
nice, so basically the only really added step is the mounts and cv joints?
OK here are some pictures of everything I removed
A
This is the bracket to the a/c compressor there are three bolts on this side and 2 on the bottom
A
disconnect all the sensors and plugs any vacuum lines
also don't forget the fuel lines
here's some plugs by the power steering under the car that you have to undo
undo the lines of the transmission
undo the motor mounts I forgot to take a picture of the other side its underneath of the car on passenger side just two bolts on each side
I just undid the bolt on the tie rod and the center one because I'm parting it out but it can mess up your alignment if you don't have it straight When you put it back
And there Matt more pictures just to please you lol
