GTPJason
I started having issues with my '00 GTP a few weeks ago. First it would stumble/hesitate once or twice a day. Then it gradually got worse. To the point where it would just die when I came to a stop. Then it wouldn't idle no more than a minute before dying and making a pop noise.
I came here and searched and found that maybe the MAF was bad. I unplugged it idled and did not die. It was more drivable but it still sucked.
Codes I had stored were P0300 and both O2s
I put a fuel psi gauge on the rail, 43#, pulled pump assembly to verify no collapsed tube/hoses, cavitated sock... all looked good.
I fixed my blown out resinator with a piece of straight pipe welded in. I installed a new fuel filter, & post CAT O2 sensor. STILL SAME PROBLEMS.
I bought a new Duralast MAF sensor and installed it. It would not even rev past 2,000 RPM. Again, I unplugged it and it was drivable.
I tooK the sensor back to the store and got another one. SAME THING. unplugged it and it was drivable.
I bought a scan tool (actron cp9575) cleared the P0102 (from being unplugged) Plugged in the 2nd sensor and this is what I found.
@ idle. the MAF #s would jump around from .67 to 1.30 LB/M
FUEL trim short 4.x
FUEL TRIM LONG 16.X
I took back to the 2nd sensor and exchanged it for another one. SAME CRAP. unlplugged it, now it's sitting in the driveway.
I'm lost and need some help to where I go from here. Thanks in advance.
FUEL trim short 4.x
FUEL TRIM LONG 16.X
