GTP stock camber
ILoveAudi
Never Be A Tim.
I was looking at my ca.r and I noticed the back tires had a slight tance. Is this normal? Just never noticed it before until now
yup, especially if the suspension is older.
anywhere from just under 1* to around 1.5* is typical for a 'stock' alignment. the rear will have noticeably more camber than the front at all times.
It's 15 years old lol. I was with my sister backing out of her driveway and I was like "What the **** is that?!" I guess I just never noticed it which is odd because I'm very observant. Thanks though :)
Here are specs for our cars.
Then pull back the carpet in the trunk and look at the strut towers, if they are rusting away thats part of the issue.
Otherwise if thats not the issue, then you need new rear struts and an alignment.
F***. Rusted pretty f***ing good. I can tell that's the problem too because the driver's side rear camber is worse than the passenger side rear. The driver's side is very rusty...
