gtp pcm security question
l67ss
Ive heard there is a couple yrs of 2nd gen gp pcms that dont need unlocked to use it on another car. 98-99 right? Thanks :)
Security learn is with the key itself, if the security light is flashing. You an google the procedure.
Case learn, aka cam and crank sensor relearn can be done with a aeroforce, hp tuners, dhp tuner and a tech 2. Maybe even a snap on modis.
Figured out you can run a 98-99 gtp pcm without flashing as its pk2. 2000+ are pk3 so you have to relearn it. Been running a 99 gtp pcm in my l67 swapped monte 5 monthes now :)
