GTP Fuel pump.. Will a GT pump work?
azmattaz06
I have a GTP with a bad fuel pump, But i have a brand new one from a GT i believe sitting in my garage. On the actual pump itself i see there's a difference the GTP pump has that extra small black hose.. I was wondering if the pump itself from a GT can be used on a GTP? Not the whole thing just the pump. Thanks
Autozone shows diff numbers, but thats for the module. I would just put in a 255lph if you are planning on doing anything to the car in the future.
Sent from my Droid
Limited budget so I don't have any plans on adding anything to the car at all.. Just can't find a good gtp fuel pump wanted to use this gt pump even though its slightly different
Ok so it did work, I noticed a reduction in power though which im assuming is because the SE/GT pump doesn't pump as much fuel as the GTP pump would?
If you noticed a reduction in power thats very bad. I doubt there was a actually a loss. That would point to the car leaning out in the top end which = no more engine.
Sent from my Droid
