gtpeddie
Whats up guys, lately in this cold weather I been having a problem with the door locks on my car freezing up usually when the temps drop below 25* or when it snows. Its the driver door that is usually the worst. I dont have a key pad and when I put the key in the door and try to turn it it doesnt move, its like its the wrong key its that tight lol. Sometimes I can jiggle the key back and forth and it will turn. So when it freezes up so bad the key wont move I go through the passenger side, and when I hit the unlock switch on the door panel the lock above the door handle on the inside wont even move. Even if I try and unlock it manually from the inside it wont move its so tight. I can eventually get it to move if I keep messing with it I can finally break it free. This only happens when it gets really cold never had this problem in summer, I did have this problem last winter though too. Its like the lock is literally frozen lol. I haven't took the door panel off yet to see if anythings going on or have tried anything to fix it yet, I was just wondering if anyone else has had this problem before and what have you dont to fix it.
