DirtDog
So rant time because fu*k glow shift and their $hit gauges. So I out my glow shift gauge in several weeks ago and ever since that gauge reads between 7-10 psi higher than the actual oil pressure. I've contacted them and they had me get ohm readings from the sensor and said o it's fine. Sensor is within specs.
I then asked then why the neck does it read high. Response. We don't know. Could be mechanical gauge is off.
Second problem is my back light quit working the other day. Won't light up. Called about that today and was told they would replace it.
Gave them my debit card info to pay for new one (refund when I return old one) and my card wouldn't process. Said I was giving them the wrong billing address. Which is BS because I'm holding a statement in hand and says the address I have them is the billing. Checked banking website. Same thing.
Well considering where I am with this car I like knowing what my oil pressure is. They said I'd need to send in the old unit before I get a new one.
So long story short....they suck. I'm ordering one of AEMs good oil pressure gauges that can rely on. Then sending in this one to get fixed. So I'll have this gauge back and will probably sell it for dirt cheap. Cause it's worth about as much as dirt.
