Anthony Smith
I would wet sand the tips and take the polish to them. Their already smooth, 10-20 minutes and they would look like chrome.
I thought the code popped up after I switched my wires, but I'll reset it and try it again. Any idea how much fluid the power steering takes. I just keep topping off the reservoir and then refill it after driving around the block.Did you clear the codes after you fixed the wiring? Been there.. gotta clear that. It's kinda funny. Both of us could goof up the same three wires.
It seems to be working just by adding a little at a time. When I replaced my rear TAs and removed the hub assemblies, I must not have put my parking brake back on correctly(or it needs adjusting) because the parking brake does not currently work. It works a little, but not enough.if you had the lines to the rack emptied out, then installed the pump, it needs to be bled, if you jack the front wheels off the ground, then turn the wheels lock to lock about 10 times, its should burp all the air, top it off and it should be good to go.
I saw your pics over on the Regal site I think it was, they're turning out nice. I did mine last summer and was real happy. But they look like garbage now, especially with no cat
