Longer = Quieter. Shorter = Louder.
Scotty hope you don't mind me digging this up. Your detailed post ALMOST answered all my ?'swhat i did was measure the res that was in my car, it came out to 28 inches long, flange to to the end of the outlet tube. stock outlet is 2.25 inside diameter.
i picked up a 32 inch glass pack cut the inlet tube off one side, and welded a flange on it. made it roughly 29 1/2 inches long. it cost 22, the flange cost 10, the welder got me for 20, new gasket was 6. vs a new replacement walker res for 100 or more locally.
my car already had the stock cat back replaced so all my pipes and stuff are clamped not factory welded.
if you have the stock cat back your going to need to go to a muffler shop, have the old res cut out and the glass pack welded in, unless you can weld yourself.
if your cat back is not stock, un bolt it yeah right, break the bolts from the cat to the res and drop the whole exhaust and then work on getting the res off the pipe. i used a cut off wheel and scored the outlet tube with 3 lines and just pealed the pipe back till it came off.
Yea I'd rather it all be flanged and bolted. Thinking I'm gonna install the DP myself to my stock cat-back with it's completely destroyed resonator then take it to the shop with a GP in hand.ive yet to deal with the DP never touched those bolts. the other two just get a pair of bolts 1 1/2 inches long a 1/4 inch wide threads and a fat washer for both sides.
got that at the hardware store for like 2 bucks or less.
thinking out loud, you should maybe get the dp installed at the same time. this way they can weld it all up, or they will need to install a flange on the glass pack so it fits like stock.
i kinda like the idea of having the bolt up flanges myself so the cat back can be dropped easily if need be.
YEa its driving me CRAZY. There's about a 10" section on top of the res that's completely rusted and gone. I think all this salt on the roads accelerated its downfall. Between the drone and interior trim rattling, makes me wanna put it in a ditch lol.no problem. i know what its like to hear all that leaking, it sucks.
its so nice now that the whole cat back is all new parts. its so silent now. all i hear is blower whine.
