CrazyGuy03
Active member
Sounds like a solid set up. Have you posted any pictures of the process or new parts ?
Don't worry about messing up your lim gaskets. As long as you have the metal ones, which I assume you do, then you'll be fine. I've had my LIM off several times since I swapped to the metal gaskets.
Do you have a complete GenV blower?
you just install it using a Gen 5 blower gasket and run an adapter to use a drive by cable throttle body on the 4 wheel drive by wire flange
Not if he doesn't have the LIM
Sent from my SM-N910V using Tapatalk
Oh yeah, I thought you meant swap lims.Huh? I thought we were cutting the gen3 lim for the genv
