Gen V Swap
should i still tap the tb if i am intercooled with a gen v and using a gen 3 lim and gen 3 core?
I'm not confident that the tiny groove ZZP Gen 3 LIM will line up correctly for proper PCV operation with a gen 5. You will have to look and see if all the holes line up. The intercooler should work with then gen 5.
Unless your throttle body adapter has a port for PCV you need to drill and tap throttle body.
If you connect this tapped hole on TB to front valve cover it should work! It will work this way if your gen 3 or gen 5 with an Intercooler and a L67 TB.
