bbptech
Ok so i took my IC apart to reseal it with anaerobic sealant this time instead of RTV and found some things. In one section there is quite a bit of oil but in the other sections they are clean. Both the top and bottom plates there is oil in the that one section. should there be that much there? when i set up it puddles to one side that gives me the reason to believe thats too much but i could be wrong? there was a layer in the LIM as well. that normal? Also when i got the plates apart, there was some oil in the section where the core sits.
heres pics. the oil in the LIM, the pics dont do justice by showing it but i tried to get a pic to show anyways.
Here u can see the oil im talking about in this section of pcv passage. This is on the top plate on the rear of the IC.
This pic is also of the top plate with oil. But u can also see a little residue on the plate where the core sets. how is oil gettin there?
Here is the bottom plate. also with oil in the passage just like the top plate.
Could this be that the pcv valve needs replaced? I almost wanna run an external pcv setup now but dont know how to setup. If someone that has a full external pcv setup on there intercooled gen V or gen III setup feel free to enlighten me on how to do it and pics would be great.
look forward to all of u helping me out.
Thanks,
Colin
Thanks,
Colin
