kawasaki22106
OK so i tore my trans apart today and found one of my thrust washers was trashed between the gear and channel plate, my 4th gear hub was rubbing the chain gear. Both gears have some rash on them from this and the 4th gear hub has rash on it and also the channel plate. Any ideas on what caused this?!?! The chain and gear set was a 7/8th 2.93 ratio.....
channel plate
4th gear hub
drive gear (this is where the bushing was trashed) i removed the retainer clip, it was installed.
driven gear
channel plate
4th gear hub
driven gear
