Gauge Cluster Not Illuminating Properly
sgtBlackburn74
Hey everyone! So, as the title explains, the driver gauge cluster is not illuminating in certain spots, or isn't properly illuminating. (Ill include a link to my Google Drive at the end that contains pictures of the Cluster on max brightness)
About 3 days ago i removed my gauge cluster from my dashboard to replace all the bulbs and switch to LED bulbs at the same time. Now before some of you freak out saying the LED's are whats causing the issue, i will let you know that the problem was there long before i switched to LED bulbs.
My going theory at the moment is that where the bulb housings are supposed to touch the paper like circuit board on the back, it has somehow worn down too much and so the housings aren't making any contact or making a very poor connection.
This may not be the case, but if so, does anyone know a way i can fix this?
This problem is extremely annoying and i would really love to get it fixed without having to put a new/used Cluster in it!
Thank you!
(Google Drive Link)
https://drive.google.com/open?id=0B4uuN2oZ1HZqcWFUNjNwZ3REbmc
