Gatorback Belt size for stock S/C?
SnowDrift
4060660 is the belt RockAuto said I needed, so I ordered one. It does NOT fit. Is the correct size for a stock setup the 667? I came across this in a post, but wanted to be sure before I order another.
It seems strange that all the belts listed were roughly the same length, by description. Apparently, they're all wrong. I usually get my belts at the dealer, but decided I'd try one of these Gatorback belts since the accessory belt is one.
Looks like the 667 is named on the Intense site.
FWIW I did actually get a 660 belt to work on a stock pulley. It's really tight and maxes out the tensioner but I was in a pinch and it worked just fine.
This thing is just so tight that the only way I think it would go on is to "roll" it on and I didn't want to do that. Numbers are all worn off the old one, so I can't see what it is. I contacted the place I got the belt and asked if they would do an exchange. If not, then I'm sure I can move it on this site or on a popular auction site.
