Fuse box question
DirtDog
So I need to add a new fuse for something in my car. I've already ran all the wiring but can't for the life of me figure out how to add a new fuse to the fuse block. Do I need to take out the screws that holds em in place and do it from the back side?
Sent from my DROID RAZR using Tapatalk 2
You don't add to the actual fuse box. That's just stock wiring. You'd need a fuse holder that usually just gets placed anywhere in the dash out of sight inline with the item your trying to fuse.. I think that's what you mean..
Sent using my Galaxy SIII on Tapatalk 2
O hadn't thought of that. Would an audio shop or best buy carry them?
I'll give the inline fuse a try...anyone know approximately what size I should use? Its for my led's I'm putting inside my glove box, the little cubby below the heat controls, and the armrest in-between the seats.
and i did the same light you speak of except the in-between. i did mine in the door pockets and cup handle. You making it so you can turn them on manually? I had put mine on the dimmer with teh rest of the lights.
Yup manual switch. Just in case I need a little light somewhere...I already ran the wire and put the switch in place but don't wanna power it off the already existent light due to I already have a lot of lights powered off it
Look on my my ride thread. I swapped out all the stock lights with red ones then added a ton of red led's hidden under the dash cause it just wasn't bright enough the I retroed the trunk with super bright white led strips. I and added lights for the back seats cause gxp have no rear lights for rear passengers
Sorta. It looks a lot better cause just the ones at the head aren't bright enough. I hid them under the front driver and passenger seats. But it really does make a heck of a difference
Well when we go somewhere at work we all car pool. But its the way I like it. But u think like a 10 amp inline fuse is more than enough
