I don't know what I'm talking about, but that doesn't make any sense; the supercharger is always running because it is belt-driven.Its suppose to switch speeds when the sc kicks in.
Two speed isnt for performance iots for reduced noise and Extended life of the pump
ok so what your saying it doesnt raise the fuel pressure...Cause im asking about is fuel pressure to see if my system is working properly...cause if i bypass the resistor, fuel should change shouldnt it?
The regulator controls fuel pressure.
if u did u would know that any fuel pressure regulator will keep a constant pressure unless the fuel pressure went rediculiously above norm or below regulator setpoint...u knew the answer already if your above statement is true...second who is the everyone u refer to as everyone has been stating the oppositeOk so all I needed to know was does it effect pressure...because from what I read everyone makes it out as if that's what it does. And no need for the link..as I said before, I have plenty of experience with cars, just not gtps....the whole reason I come to this forum. Thanks for the feedback.
