David99GTP
Was wondering something before I try and crank it up. I feel stupid but I have had the car apart for over a month. I have forgotten what some things go to. Question one is how do I tell the two fuel lines apart? What line is the return line? What will happen if I have them switched?
Second Question is my coil packs. There is a ground wire that is bundled with the wires that plug into the coil packs. Where does that ground attach to? based on how long the wire is I figure either to the bolt holding the fuel rails down or there is a bolt hole near there on the block. Maybe I am missing the screw and it bolts into the hole grounding to the block? I want to make sure I am 100% correct because I have the MSD coil packs and I know they are evry sensitive to being correctly grounded. Thats the number one reason they fail.
Thanks in advance!
Thanks in advance!
