Tengis
To get MOAR performance you need MOAR fuel! Fantastic pricing on 255lph and 340lph fuel pumps for just about every make and model! All pumps come with a 1 year "no questions asked" warranty.
255lph pumps that fit NON-VENTURI and VENTURI Grand Prixs start at $75 for LOCAL PICK UP or with FREE shipping to your door (typically received in two days).
E85 safe while flowing more then a commonly used Walbro 255 - what more could you want??!
The non-venturi will require modifications to the canister (AS DO ALL NON-VENTURI 255lph PUMP INSTALLS INTO NON-VENTURI CANISTERS). To have a true "oem style" drop in pump then you would have to get ahold of a venturi canister and buy a venturi pump.
Our NON-VENTURI 340lph pumps start at only $125 for LOCAL PICK UP or with FREE shipping to your door (typically received in two days).
This pump is not only priced extremely well but it is also E85 safe while flowing significantly more then your typical Walbro 255 at all pressures. Fits into any canister/tank setup that a typical 255lph kit would fit!
We also carry 255lph pumps designed for RETURNLESS fuel systems like those found on the newer model Mustangs. Our returnless pump is a direct replacement but also much less expensive alternative to the GT500/Ford GT fuel pumps! These start at $130 for LOCAL PICK UP or with FREE shipping to your door (typically received in two days).
If for whatever reason you are interested in getting only a Walbro for your 255lph replacement or are interested in a Deutsche Works 300+lph pump then you are in luck! We are currently in talks with distributors to carry both locally and should have good pricing.
Email or PM if you are interested in buying a pump.
All pumps are certified and inspected to the same standards as any OEM replacement pump and have a typical failure rate much lower then the commonly used Walbro 255. We also have access to a large list of fantastically priced OEM replacement pumps that carry a lifetime warranty.
Here is a flow chart, all flow numbers were provided by RCengineering:
WE HAVE FUEL PUMPS FOR LITERALLY ALMOST ALL MAKES AND MODELS - ask about a 255lph or OEM replacement pump for your vehicle.
