Fuel pump rewire kit
Tonkin2000GT
I was wondering if anyone runs a stock pump with 42.5 injectors? I've heard some people do but they use a rewire kit what exactly is the rewire kit and where do you get one?
A rewire kit is nothing more than larger wire and a relay and fuse to run for your fuel pump. Use the old wire from the pump to turn on a relay that is wired with 12-10 gauge wire.
Jeff
Jeff
Okay does someone sell a kit? Is it necessary for 42.5 injectors?
you can either do a little digging and do one yourself. or get a caspers or a racetronix. stay away from zzp's rewire
Nope. I just bought a racetronix on yesterday because I switched to Aussie style fuel rails and the #5 cylinder is the last to get fuel and now I have a mysterious #5 misfire at idle only. I'm thinking since I don't have a return, the #5 cylinder is starving of fuel. I ran 42s on my stock fuel rail setup for two months with completely no issue
Where did you get a racetronix at?
