fuel line question
LOL, I do have internet at home. I'm also often very busy. Logging in is not always something I get to.
I see it.. Looks like the relatively reasonable priced dorman fix a fuel line kit. As long as you get it together and it seals, you are golden. Personally though, I've seen 3 leak and only one friend have success with it. I personally think she cheated or something, but it worked for her. (right, chick installed)
If successful, it should work well. Mine leaked.
Mike..if you Swagelok..you aren't getting those for under $50-60 for the set. Currently my local swage distributor ordering the 500 fitting said 4-6 weeks on it instead of the usual week or two. it took 4-6 to get it.
I feel like that's a trick question. You'll be using a repair kit to swap the lines over. It shouldn't leak...if it does..try another kit?
