SyntheticShield
How much would you say you had in that one line?
sweet zzp fuel rails have the provisions to just mount this type fuel line straight to it. I am defenitely doing it now.
Great info sra_chipmunk.
Now the blue fitting in between the two red ones, what kind of fitting is that. Is that a compression to hose adapter, male to female? I guess I would need a couple of those? Just trying to put together a list of what all I would need.
Hey sra_chipmonk.... do you have PNs for all those fittings you used? I wanna make sure I get the right stuff and not waste money on fittings I don't need. I already did that on my IC install with Aeroquip fittings. :-(
What sizes are the inlets and outlets? I want to do both lines on my car. That line you cut, you left it installed? Is it hard to remove?
Also, when cutting the tubing, how do you prevent metal shaving from getting into the line?
Thanks,
Yeah, I cant say that I blame you.
So you got about 6' of SS braided line, thats all? Thats considerably less than I thought it would be or is that just from like the firewall to the rails? For some reason I was thinking all the way back from the tank.
I'll look up the prices on -6 AN stuff and see what that will run, maybe I can piece it together over time and do all that when I yank the tranny.
