There is a possibility, not a big one, but there is one. If you want, try clusters first since that will save you pulling the pump. Also, if that checks out, Check the sending unit ground, if that checks out then the way I go after that is, take the connector off to the sending unit, the square one with the ppl, black, black/white stripe and grey wire, disconnect the battery, use a power convertor, or some other way to put power through the ppl wire from the plug, then go to the PCM, disconnect the clear PCM connector, find PIN 69, it will be the ppl wire, and test light it to make sure there is voltage there. That is the whole circuit. It goes from sending unit, ground in the PCM ground group, and the ppl wire goes to the PCM as the fuel level input, which is then send by the PCM to the gauge cluster.
