[FONT=Tahoma, Calibri, Verdana, Geneva, sans-serif]I tend not to respond to others posts, but feel I want to here...
Unless towing or racing, the SLIGHT loss of low end torque would be offset by the flow gains in the use of headers. A plog is half a header and a waste IMO. Secondly, the N/A doesn't need headers argument is off base, as then any of other engines out there without S/C or turbo are not benefitting from headers? Come on... we all know these engines, both the 3.8 and 3.1 suffer from flow restrictions... Anything done to open or smooth the flow will benefit efficiency.
The right answer would be, does the cost/gain mph seem justified? But if you gain let's say 2 mpg and take the avg 12,000 miles driven, at 20 mpg (avg) you consume 600 gallons of gas. Let's assume at 18 mpg without headers and you'll consume an additional 67 gallons for the year. 67x$4 (+\-) = $268... Pretty much covering the cost of those cheapo headers in just one year, this is without changing driving style. *** I know and allow for a lot of assumptions, but just want to make an example.
Sometimes, it's just a matter of sense ($.02), lol, pun intended.
And the tune would dial in the PCM to his specific engine, alt, temp, etc, making it a little better than stock. Although with this one, I'm not sure the cost could be covered by the gains... Unless the tuning is already a able so no cost.
Otherwise, yes, the OP did ask if there was ANYTHING that could be done to make it a BIT better...
: )[/FONT]
