silvermistgt2002
Seems to be a common problem judging by some of the other posts I have read. 2 problems currently with this car.
1. Clunk in front end while traveling at speeds of 15-40 mph when I hit bumps in the road. It has been getting worse over the last 6 months. I replaced the strut, mount and all that about 4 months ago due to bad struts, and thinking that might have been the problem. Did not fix the issue. also replaced the sway bar end links. Other thoughts at this point are either the control arms, or sway bar bushings.
2. Click in the front of vehicle, and under the driver side dash. this DOES NOT happen when I am driving, only when stopped and the wheel is moved back and forth quickly. I can feel it in my feet, and in the wheel. It did have a very slight almost not noticeable click when I bought the car in 2011 but it also has gotten worse. Both front out tie rods are new, now play in anything when I checked the inner tie rods. My thoughts at this point are the steering shaft, or steering rack bushing. I don't think its the rack because the steering is still perfect with no dead spots, or hard to turn spots.
Thoughts?
Thoughts?
