Front brakes from a 2006 GP on a 2003?
would the 2006 impala ss Rear brakes work I understand that the E Brake wouldn't work but I have a solution for the E Brake
So how much better would a rear GXP brake setup be over the stock 2003 GTP setup?
Theres not really much need to upgrade the rears if you've done a front brake upgrade, fronts do most of the work.
Replace pads and rotors in rear if need be and bleed the them and you should be set if you've done a front upgrade.
As to the comment about braking is all about pad surface area and not cooling i hav to disaggree if that was the case wed b running 4wheel drums cooling is a MAJOR part of braking plus theres the whole leverage thing
