Front Brake Upgrade for 01 GTP with Stock 16" Wheels
mikes01gtp
What is the biggest rotors that fit? And what donor car can I get them from? What is all the parts needed to make the conversion?
12" is the biggest you can fit. You need caliper, bracket, rotor, pads, and possibly banjo bolts and lines
04-08 GP single piston front I believe. Want mine? Newish full ceramic pads with 3k on them. Hardware. ..banjos and new copper washers as well
Those are smaller than the F body/impala/monte carlo rotors from the 00ish era.
06+ impala pads calipers rotors would be nice.
All you ACTUALLY need to swap to 12" rotors are the caliper brackets, rotors, and pads from a 00-05 impala with 12" rotors.
The caliper brackets will swap out, that's how the GMPP kit came.
I thought of doing that too but I figured I could help someone that needs a stock replacement or minor upgrade first. I keep them away from the elements but another month and ill probably trash them.
