jmoore4294
So I put my SSC springs on the front of my car today. Didn't have time to do the back. Anyway, everything was going great until I went to put the strut back in place. Hand tightened the 3 top ones to hold it in place, did the 2 bolts that hold it onto the knuckle. Buttoned everything up and went to tighten the 3 nuts up top WITH A RATCHET, mind you not an impact, I got two of them done and the last bolt sheared off. It sheared off. It sheared the f**k off. Thank god autozone has these in stock. Went and bought a duralast one. Nearest autozone is 10 miles away. Lost some time doing that. Came back, got everything perfect, went to do the other side. Everything was going well until it came time to tighten the 3 nuts up tops. Got two of them done, did the last one (still using a ratchet mind you) and the last one sheared off. It sheared off. It sheared the f**k off! In the same spot as the other one. It's too late to go get a new one. Hopefully I can drive it tomorrow and not have any problems with it until I can pick up a new one. I figure as long as the weight of the car is on it, it won't come out.
But good god. Both in the front in the same spot? I fear what will happen when I do the rear tomorrow/thursday. I mean really.
