Scottydoggs
Killa Bee
Well, the fan blasts and only minimal amount of air will come out of the vents. AC 'works' it's cooler than the hot air, but not ice cold air. Boost gauge doesn't work still, I'm assuming it's from that T connector missing. I'll go to the auto parts store on Thursday or Friday when I have time to get some parts to make shift a T connector. If I fail, oh well. I'm still waiting on the connector to show up in the mail![]()
look for the other side of the taped off line. if need be you can slide a new rubber vac line over the hard line and make the connection. your boost wont show cause the map sensor is not seeing any vacuum. car must be running like crap with a leak like that.
follow the diagram posted up there and make sure its all plumbed back right. should be a night and day difference.
if you get the taped off line reconnected to its other 1/2 your a/c and heat will work like it should. like i said earlier, look under the fuse box on the pass side wheel well for the other side, its a hard line like up top where its capped.
