For you guys runnin 20s on your 97-02 gtp
LeThAlREMiX
I just put 20s on my gtp today, and sometimes when turning i get a slight rub in the front end, anyways to fix this?
just put 20's on today, tire size is 255/35z/r20 they have a slight rub in the fenders when turning, just gotta cut a piece of plastic, and you cant have your back seat loaded. it rubs if theres too much weight in the back, definetely nice to do to a car tho, i have alloy tech deuces, heres a pic,
its rubbing inside the fender like on the plastic piece i think, just when i turn the edge of the tires hits i think, and in the back an massive bumps im grindin on plastic too
not quite sure, past owner might of lowered it, ithink i have the adjustable suspension on it, ill take a look later on
either trim your inner fender or rip it out. that is what's rubbing.
or just drive it and let your tires wear through where it rubs and you dont have to do anything.
Wouldn't this also cause excessive wear on the tire in that spot? First option is probably wiser. ;) :D
i took a look in the daylight today, i know exactly where its rubbing due to marks on tire,
what should i be doing in this situation?
