FMHE
papaspanky
OK my car has been running a little warmer than useual and after a coolant flush and a bad coolant elbow I noticed most of the fins on my ZZP FMHE are bent stopping air from going through. my question is this will I be better off running a wbody store dual pass fmhe or a schirocco style radiator?
thats one of the probs with the zzp one its to wide to fit in close.and I would fix the fins but due to wideness (did I just invent a new word?) I am going to change it out.I do have both of the mentioned fmhe's
I do not know if the WBS will mount in close either.
Its designed to sit on the bottom of the bumper support.
So it forces you to mount it too far forward causing cooling issues by just being there. Also makes it less effective.
