Dancing Bear
Good ol' Blackjack (my 02 GTP) is making a noise.. I went 3/4 throttle down the road to get to my chorus performance on time, and when I pulled up to the parking lot I could hear a knocking/banging sound. Limped the car home, got under it searching for what I thought was a rod knock at first.
Probed around with my stethoscope, discovered the noise was coming from the bellhousing. Removed the inspection plate and rotated the crank slowly while my mechanic neighbor inspected everything. After multiple rotations and a very thorough inspection, we found no cracks in the flexplate, but we did discover that the welds on the torque converter have a small crack in each of them.. They don't look very deep, and they're not very long, maybe 3/4 of a inch
While the engine is running, if you rev the engine the whole assembly will shift back and forth (~1/2in). The noise increases in frequency as you rev the engine up and down. Car is slower than normal to turn over, but fires right up. Oil was changed and had no chunks/glitter indicating a bad bearing.
I'm assuming the slow crank is from something dragging on the inside of the bellhousing or on the serpentine belt drive
My neighbor who was a mechanic for many years mentioned that these cars are notorious for having bad harmonic balancers, which could cause this issue and the noise would travel down through the crank to the bellhousing
Any ideas are, as always, very much appreciated!
