FINISHED!! Dash Z LED Projector Headlights! Review!
As far as adjusting goes.
Its 2 Screws if you tighten the top one the Beam goes UP but you also need to Loosen the lower one for this
and if you need the beams lower Loosen the top and tighten the bottom
My night shots have them extremely high which i need to adjust again.
As far as highbeams Its got a Bulb in there but the Highbeams dont come on with a HID kit (Not sure why) but at anyrate the HID's are 10fold more brighter then the highbeams anyway.
Just got mine and I installed them tonight... They are pretty nice and a lot nicer output then the stockers. I'll be writing my review after some more testing ;)
Stock bulbs are H3's and highs I think are H1's?... and yes the highs do work.. but I do not have a HID kit in right now.. I'll let you know what happens when I get the HID kit.
my highbeams dont work with my HID's
and i snapped the back plastic ring of the Inner Plastic Mounting brackets ( the ones near the grill on each headlights)
JB Weld fixed it thought lol.
did you wire the Halos to the Low beams? or the parking lights?
and give me a photo of your LED's and halos.
i wanna compare
I wired them to the orange bulb, just because I wanted them to flash with them when I put my turn signal on. Since I have disabled DRL's all I have to do it flip the switch for the lights once and all the halos/led's will come on along with the turn signals... but not the low beams, which is tight.
I'll get pics up tomorrow if I have time after work!
So do the highs work with the HID installed I don't believe I caught the answer to this. As well could you let me know how you hooked up the halos/led and turn signals to a switch? Thanks, I am looking to get some more light out of my 00 gtp as I do a lot of driving for work and it seems like everytime a car comes towards me I can't see because my s**t headlights and i just wasted 60bucks on silverstars didnt help much at all. Any suggestions as to what I should go with to solve my problem would be great.
When have we been concerned with the law? LOL What the law says Vs. What makes my car look good..... Ill take my chances with the PoPo :th_winking:
There are some tickets that can be thrown out 99% of the time and I don't mind taking a risk with those.
Its the ones that stick that I pay attention to.
ur low beams dont come on with the high beams because the factory lights are one bulb. the relay switches from high to low. there is a way to rewire around that but i dont know what it is. its not the HIDs or the projectors that cause this its the factory set up.
id really like to see a pic of the cut offs.
my fog HIDs in hella angel eye capsoles put out way more light than my projectors. but i really love the way these ones look! and now they are on ebay for 230 shipped. by the time i have the extra money to get them i hope they are under 200. i got my spyder ones for around 160 shipped.
So the bracket for the capsule broke!? Sounds like the same problem we have with the Gen 1's. And I haven't really heard anyone do any type of review about the cut-off. No pictures of the capsule mounting locations other than a blurry pic in the first post.
Seems to me like these are just about on - par with the Spyder projectors. Only problem I ever had with the spyder's was a broken mounting tab, and I seem to fix it with JB weld every time it comes loose.
I was ready to jump on these if they were a ton better than the spyder capsules. I don't like the design of these as much as the spyder capsules.
Well it was just the inner one. its because i overtightened it. lol
But you see this is what happens with an item like this. You overtighten the bolt in hopes it will solve some bouncing or something like that....then POP!! It snaps. I don't have bouncing in my spyder capsules, but I did overtighten the bolt last year when adding spacers, then SNAP! it is the inner one also.
All I'm saying is people are grabbing for reasons these are better than the spyders.....and that is yet to be seen...
well i don't have any bouncing issues with these at all.
The only problem that plastic part is. I have to have a pair of pliers to hold the washer in place when tighting the bolt down. Going to JB weld it when i get the chance.
Spartan if you could PM me,
I have few questions about installation...
I just bought the Black LED projection headlights with the 6000k hid converison kit, just wondering how to wire it all and if you got pictures to help me out.. would appricate it,
far as i understand
steps are...
1. take botls out
2. take the wires all out old stock lights
3. disconnect battery obviouslyw ould be first i gues..
4. take the rubber cone off back the projection headlights ( one with the bulb i assume???) because mine has one thats like a blacked over looking one and one that you see the bulb clearly.
5. cut the hole quarter size to fit the hid bulb into through the rubber and make it waterproof (live in pennsylvania there is lot rain here too)
6. take ground wire from that projecter frame and ??????
7.... take the red wire off the project frame and ???
8. how to hook up the LED and HALO rings....... possible hook them into my switch? oH and im also wondering if u have stock fog lights??? or aftermarket foglights?
9. found mounting places already, but question is how to go about wiring ect... if u have pictures and or wire diagrams let me know PLEASE
PM ME!
