Finally continuing customization...
Hopefully its before you burn up the fuel pump by causing it to strain to maintain fuel pressure through a clogged filter, cause then you'll have the enjoyment of replacing not only the $6 filter, but the $$$ pump as well.
In the past people have let shops try, fail, then force them to replace the line at their cost.
Not condoning that method though.
And for this I wouldn't even consider Jiffy Lube, unless of course you don't like you ride. Find a good independant shop and have them give it a go. They would most likely be able to deal with this better than an oil change place.
