I'm not sure if it will work, otherwise i will have to ask one of you guys how to upload the video otherwise.
I will try to embed the video to see if that works, the preview post isnt helping me to see weather it will work or not.
<iframe src="Facebook" width="1280" height="720" frameborder="0"></iframe>
Mod's are Ported LIM and inlet/outlet ported genIII, stage 1 ZZP throttlebody, TB spacer, 42lb injecters, 255 pump, 3.0 MPS pulley, XP cam, rollmasters single chain, Comp cams rods, OER lifters, 115lb springs, retainers, keepers, stock rockers, moded valve seals, balance shaft delete, a/c delete, ZZP 1.0 PCM with injecter size and shift points preadjusted (base tune) auto light 103's, 180* thermostat, 1.5" Radiator core, acessory trans cooler, ZZP transmission, with shift kit, 3.29 gears, single chain, ZZP converter.
Once its road worthy i will get it dyno tuned, then IC with sub 3.0 pulley setup, or toying around with a statama turbo build.
