Figured I'd post up a quick "Teaser" Video of my Project car
gptuner
I'm not sure if it will work, otherwise i will have to ask one of you guys how to upload the video otherwise.
I will try to embed the video to see if that works, the preview post isnt helping me to see weather it will work or not.
<iframe src="Facebook" width="1280" height="720" frameborder="0"></iframe>
Mod's are Ported LIM and inlet/outlet ported genIII, stage 1 ZZP throttlebody, TB spacer, 42lb injecters, 255 pump, 3.0 MPS pulley, XP cam, rollmasters single chain, Comp cams rods, OER lifters, 115lb springs, retainers, keepers, stock rockers, moded valve seals, balance shaft delete, a/c delete, ZZP 1.0 PCM with injecter size and shift points preadjusted (base tune) auto light 103's, 180* thermostat, 1.5" Radiator core, acessory trans cooler, ZZP transmission, with shift kit, 3.29 gears, single chain, ZZP converter.
Once its road worthy i will get it dyno tuned, then IC with sub 3.0 pulley setup, or toying around with a statama turbo build.
Can anyone tell me if the link is clickable? I can click the facebook part of the link and it plays for me just wondering if its working for everyone else
[video]http://www.facebook.com/video/embed?video_id=10151209185444762[/video]
It works, reposted it for you...
sounds pretty rockin, kinda of a short little run you did there...must have good brakes
Remove the TB spacer, worthless mod.
But otherwise that project sure is different, should turn a few heads thats for sure. Good thing you'll get a real tune on it before you take it on the road, I'd never trust a canned tune with those mods.
Need flash player FTL.
thanks for the new link, it has the stock brakes suprisingly thats why the rear squats before i nailed the throttle after preloading it. Picked up the car for 800 bucks with a 2.2 with a blown head gasket. Only has 60k on the body which is in good shape apart from a few dings here and there.
Its pretty much a junkyard motor with less than 90k on it out of a 99 GTP i got complete for 600 bucks that i went over and cleaned up a bit. The entire wiring harness i got from a salvaged 98 GTP, fuse box and all. engine and transmission bolt up directly since it was designed to fit not just the 2.2 but the 3.1 and 3.3 liter so the subframe already had the bolt holes for it the axles from the HD transmission are the same spline and depth so they slid right in and bolted right up.
I just had to reinforce the upper rad support and drill holes to mount the upper wishbones thats about it.
