1997 Buick PAU. Just finished installing SD headers, 3" high flow cat, 180* tstat, autolite 104s, intake, lightly ported supercharger housing outlet, and 3.4" pulley along with an Intense PCM and a bunch of new gaskets and maintenance items.
The car is running smoothly and as good as it did completely stock. The problem is, the car really doesn't feel any more powerful than stock.
I scanned using a Bluetooth adapter and Torque Pro and I'm seeing spikes in KR of up to 4-5* in 1st gear and as high as 6-7* under WOT in 2nd gear. Thinking it could be a fueling or o2 problem, I watched my AFR in torque and it's sitting at 14.7 at idle and 10.5-11 or 900mv under WOT which if anything seems rich and directs me away from a weak fuel pump, but besides that I'm at a loss. My pulley is really not very aggressive and with my mods I was expecting to be on the safe side of pulleys so something doesn't seem right. With Torque measuring my 0-60 with just my 180lb self, I got 7.7 seconds.
Here's a link to a 0-80 run monitoring my o2 voltage and KR. Sorry about the glare and shakiness, it may take a few plays. The KR peaked at 5.2 in the video and the o2 voltage seemed to stick around .9V at WOT.
https://drive.google.com/file/d/0B8V...w?usp=drivesdk
I was getting a P1133 immediately after fitting the headers which may point to the o2 but I'm reading of a lot of guys seeing this after header installs while the copper rtv burns off. The code comes back periodically, but even so wouldn't I be running rich and not getting so much KR?
I did test my fuel pressure, and it seems about right as well:
Key on, engine off, the pressure is 50 psi.
At idle, the fuel pressure sits at about 44 psi, and bumps up to 50 psi if I disconnect the vacuum line to the pressure regulator.
I ran a rough flow test by bleeding the line off the pressure tester into a wine bottle while the engine was at idle and came up with 43 seconds for 750mL. By my calculations, that's .275 gallons per minute or 62.6 Liters per hour. During this test, the pressure sat at about 10-15 psi (meaning my testing apparatus was resisting flow). I do not see any validity in this test at all for flow rate, but it's worth noting that the flow seemed consistent and I didn't see any aeration during the test or anything and the engine had no trouble maintaining smooth idle.
I did go ahead and order a new ACDelco upstream o2 sensor as the most logical explanation to me at this point is bad data coming from a faulty upstream sensor, but I don't have a lot of confidence in this.
Input?
Input?
