Keko
As summer the summer heat has progressed, so has my coolant temps. I've been a little curious lately because I am seeing temps higher than expected, even when cruising on the highway.
In the previous 6 months or so (colder weather), the car has been under 180F at almost all times even when doing pulls. Usually around 174F. For the last month I've been seeing daily temps of 190+, sometimes close to 200, when cruising on the freeway. Ambient temp outside is around 90F +/- about 5 degrees. The car seems to end up cooling better at a stop or in traffic compared to cruising, which is a little concerning.
I'm not worried about damaging anything at 195F since the L67 runs hot from the factory, but I do feel like the mods I have should be handling the heat better. Shouldn't cruising on the freeway bring the temps down a lot even if it's hot as **** outside? What temps do you guys get when cruising on the highway when ambient is ~90F? Any thoughts?
Relevant mods:
Thicker, full aluminum radiator with no dexcool
180* Tstat
FSIC (might slightly help with coolant temp?)
zzp canned tune with lower fan settings
Relevant mods:
180* Tstat
