WarStryker13
I break things.
Still sounds like crap.
Good. Thanks for that.our high angularity SII (short deck) 3800's have very fast piston acceleration/deceleration rates at the TDC/BDC points, this makes for a sharper, more staccato exhaust pulse wavefront.
our headers inducing a timing disparity put two of those staccato pulses next to each other, and depending on rpm, give us the "3800 Blatt".... a lower perceived pulse frequenc
3.8/SI 3800's will always have a more pleasant exhaust note with the lower angularity of the tall deck buick 6's
lol heard you had trouble at the track, how much do you have in the trans?
The two banks of exhaust need to be of equal length BEFORE they merge together. That is the single biggest ingredient in making the 3800 sound good. Everything else you place downstream is fine tuning, but the foundation for good sound is laid by making sure your header secondaries are of equal length, or as close to it as possible. That is why turbo 3800's sound better than non turbo cars, and why 3800 powered Holden Commodores can sound good to great. The factory system in our cars has the front bank of exhaust travel through the crossover before merging with the rear bank. This creates uneven pulse collision, which boosts nasty sounding odd-order frequencies, and creates turbulence which we hear as rasp when revving. It's all about the equal length secondaries, which in a front wheel drive car is not easy to achieve... but also not impossible. I know because I built the one in the above link. The red GTP is mine.
I'm going to say that the math was less of a factor in that 3800 exhaust build.The piping isn't going to make any difference with the exception of adding a Helmholtz resonator which is application specific and requires a hell of a lot of math or Dumb Luck to make work properly.
