WarStryker13
I break things.
So I'm replacing gaskets and flushing coolant, and once everything is back together I go to drive home...but I have no throttle control. I stomp on the pedal, turn it off and back on, and nothing. Engine sounds beautiful compared to what it was before, but I get nothing higher than idle. Finally get home, after having a friend push my car with his... and it sits in my parking spot for almost two weeks as I pull the throttle body off, put it back on, pull almost every fuse, scan and clear fault codes hundreds of times.... until I finally pull off the MAF clip and Voila! I get a response. until the car realizes that its not plugged in and kills the throttle control. So while I'm waiting on a new MAF to come in, I have the gracious opportunity to reflect on why an air flow sensor would affect the movement of a butterfly valve.... then I realize that since everything is controlled by a computer less powerful than my cell phone, the car will be stupid and eliminate all possibility of functioning until every freaking sensor works perfectly. And the only reason why I managed to figure it out was by smelling the un-burnt fuel in the exhaust and deciding to check the real time data from my trusty Torque app on my tablet... the MAF was reading 18 at idle. That was what led me to search and find ONE thread with a similar problem... almost bought a new throttle body because of that. But now that I get to ask for rides to work, I have very little chance of finding a decent replacement at any salvage yard anywhere close, because for some reason nobody over here likes American cars. It's very upsetting to not have the option of junkyard parts. Very. But anyways, I have two things done that were simple and easy, my K&N filter is breathing for my car(it does sound better, even being an N/A GP) and the flipped dogbone mounts make that hideous growl feelable in my butt. That makes this retarded car slightly more bearable right now...I just need that MAF to get here so I can really make her scream.
P.S. I would be perfectly happy with a carb and distributor, because this electronically controlled everything bull-honkey to just up and ramdomly quit working without warning... its for the birds.
