Evap Leak
gordster1122
On my 04 grand prix had the engine light on so hooked up my code reader and got P0446 and read it can be the evap solenoid canister so went and got a new evap solenoid just want to make sure I got the right part went to the gm dealer and got the part with a upgraded hareness part # 20941985 just got to wait to warm up outside
is that for the top of the canister in the rear quarter? if so make sure the tank has no gas in it, and that all the lines to it and the solenoid are solid.
unplug the battery while you work on it, that will clear the code, then you just wait to see if it comes back or not in a day or two.
ok was going to make attempt to fix it and tryed my impact to ge the lug nuts off so got the breaker bar and got 3 off and stripped the other 2 lug nuts when I got my winter tires on don't know what they used to tighten the lug nuts but on there super tight is there anyway to remove the stripped ones?
