98GTFan
OK i went out and got the compression tester and all 6 cylinders are just fine so i went ahead and started digging down to the LIM gasket. Taking everything off carefully and labeling all the wires and bolts and such so i can get it all back together and when the UIM finally came off it looked just like the pic you provided. coolant and oil in the center and the gasket has really seen its better days but the UIM itself seems ok and the LIM surface is smooth and not pitted in any way so im comfortable with that. Im going to take the UIM plastic to autozone or anywhere that has a new one on hand for me to closely compare the two or just replace it all together.
Should i dig down any further now that I know the LIM gasket is bad? Also, what else can i replace while ive got the alternator, throttle body, air filter box, fuel line, vacuum hoses, fuel injectors and UIM/LIM off?
